Use the move command to change the order (position) of an exception filter. The move command is available from the topology:<named-topology>:l3: exceptions context of the CLI for b@ac, physical, and routed topologies.
pos | Specifies the current position of the exception filter (0–255). |
pos | Specifies the new position of the exception filter (0–255). |
The following example moves exception filter at position 4 to 25:
EWC.extremenetworks.com:topology:r1:l3:exceptions# move 4 25
