hs-provider-frn1
Use the hs-provider-frn1 command from the provider-config context to configure the hotspot OSU provider first friendly name.
hs-provider-frn1 friendly name
Parameters
friendly name Name for the provider online signup.
EWC.extremenetworks.com:wlans:hs:hotspot# provider-config https://Enetworks.com
EWC.extremenetworks.com:wlans:hs:hotspot# hs-provider-frn1 ENetworks
