Use the sync command to enable or disable automatic synchronization of the default-role across paired controllers. Refer to the Wireless User Guide for more information about synchronization of policies.
The sync command is accessible from within the vnsmode:default-role context.
| enable | disable | Enables or disables synchronization of the default-role across controllers. |
The following example enables the synchronization of the default-role across controllers:
EWC.extremenetworks.com:vnsmode:default-role# sync enable EWC.extremenetworks.com:vnsmode:default-role# apply EWC.extremenetworks.com:vnsmode:default-role# show Assigned topology: Bridged at AP untagged Ingress rate profile: Unlimited Egress rate profile: Unlimited Enable AP filtering: disable Synchronize: enable EWC.extremenetworks.com:vnsmode:default-role#
Print
                        this page
Email this topic
Feedback
