Use the list command to display the “TCPDump file capture” list. The list command is accessible from the traffic_capture context of the CLI.
The files that are stored on the CF card have flash suffixed to their file names. For example, mgmt_traffic_dump.cap (flash). The files that are stored on the local drive of the controller do not have anything suffixed to them.
You can save only one TCPDump file on the local drive.
None
The following example displays the list of TCPDump file capture:
EWC.extremenetworks.com:traffic_capture# list
Traffic Capture Files:
    1:mgmt_traffic_dump.cap
    2:mgmt_traffic_dump.cap (flash)
    3:mgmt_traffic_dump-01.cap (flash)
    4:mgmt_traffic_dump-02.cap (flash)
    5:dhcp-relay-01.cap (flash)
    6:third-party-01.cap (flash)
    7:mgmt_traffic_dump-03.cap (flash)
Print
                        this page
Email this topic
Feedback
