Use the sync command to enable or disable automatic synchronization of this <named-role> across paired controllers. Refer to the section entitled “Using the Sync Summary,” in the Wireless User Guide for more information about synchronization of policies.
The sync command is accessible from within the role:<named-role> context.
| enable | disable | Enables or disables automatic synchronization of this <named-role> across paired controllers. |
The following example enables the synchronization of the p1 role across controllers:
EWC.extremenetworks.com:role:p1# sync enable EWC.extremenetworks.com:role:p1# apply EWC.extremenetworks.com:role:p1# show Assigned topology: no change Ingress rate profile: no change Egress rate profile: no change Do not change filter settings when this Role is applied: disable Enable AP filtering: disable Name: p1 Synchronize: enable EWC.extremenetworks.com:role:p1#
Print
                        this page
Email this topic
Feedback
