endofday
Use the endofday command to configure the duration of the guest portal access account.
[no] endofday id HH:MM
Parameters
id Specifies the ID of the guest access account and must begin with the string “Guest-”
HH:MM Specifies the duration of the guest client in a <HH:MM> hours and minutes format
The following example sets the duration of the guest access account to 8 hours:
EWC.extremenetworks.com:wlans:clients# endofday Guest-lobby 08:00
EWC.extremenetworks.com:wlans:clients# show
Guest-lobby     Lobby   1234abcd        2009-12-01 12:00:00    12       12              00:00   08:00   disabled
