priority-override
Use the priority-override command to override the priority for all packets in the WLANS. The priority-override command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the priority-override command, run the apply command to implement the changes.
priority-override enable | disable
Parameters
enable | disable Enables or disables priority override for all packets in the WLANS.
The following example overrides priority for all packets on WLANS CNL-7-CP:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# priority-override enable
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show priority-override
Priority override: enable
