This section describes commands used to define and configure WLAN services for the network. These commands are located in the wlans context of the CLI. Execute the wlans command at the root level to enter wlans context.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the wlans context:
Print
this page
Email this topic
Feedback
