Use the export command to export the floor plan to the user-readable XML format. The export command is accessible from the location:floor-plan context of the CLI.
| floor-id | Specifies the name of the XML file to be created of the floor plan (<floor-id>.xml). |
This command creates an XML representation of the internal floor plan and stores it in a local file named <floor-id>.xml. This file can then be copied to a remote location using the copy [stream] command.
The following example creates an XML version of the floor plan for the Salem second floor:
EWC.extremenetworks.com:location:floor-plan# export salem-second-floor
Print
this page
Email this topic
Feedback
