Use the show command from the wlans context to display WLAN service configuration information.
| WLANS-name | Specifies to display information about the specific WLAN service |
The Radio Mode field displays the 802.11 modulations that the AP‘s radios are configured to use.
EWC.extremenetworks.com:wlans# show Name Service Type Enabled SSID Privacy Auth Mode Radio Mode osu std enabled osu none disabled off hs std enabled hs wpa 8021x off std std enabled std none internal off
EWC.extremenetworks.com:wlans# show hs
Service type: std
Hotspot type: enabled
Enable/disable WLAN Service: enable
Remotable: disable
Inter-WLAN Service Roaming: enable
Associated WLANs: hs
Egress Filtering: disable
Radio1 Radio2 AP Name
3705i
3805i
ap3935i
3965
3805e
ap3805i3
3825i1
ap3935e
SSID: hs
Default topology:
Pre-authentication timeout(minutes): 5
Post-authentication timeout(minutes): 30
Session timeout(minutes): 0
Enable/disable block MU to MU traffic: disable
Default CoS: No CoS
Default Traffic Mirror: prohibited
Enable/disable Netflow support: disable
Unauthenticated Behavior: discard-unauth-traffic
Radio Mode: off
