Use the 3rd-party command to enable or disable a third-party port in a physical topology. Only one physical topology can have 3rd-party set to enable. The 3rd-party command is available from the topology:<named-topology> context of the CLI for physical topologies.
| enable | Enables a 3rd-party port on the specified physical topology. |
| disable | Disables a 3rd-party port on the specified physical topology. |
The following example enables a 3rd-party port on a physical topology:
EWC.extremenetworks.com:topology:esa0# 3rd-party enable EWC.extremenetworks.com:topology:esa0# show Name: esa0 3rd party: enable
Print
this page
Email this topic
Feedback
