The <named-cos> command, where <named-cos> refers to the name of a given CoS, provides access to the cos:<named-cos> context.
The cos:<named-cos> context provides commands for the configuration of the <named-cos>. A <named-cos> must first be created using the create command in the cos context. Once created it becomes available as a command, allowing access to the cos:<named-cos> context for that CoS. For example, to enter the <named-cos> context for the cos named my-cos, use the command my-cos from the cos context, created using the create <cos-name> command.
After you complete configuration changes for a <named-cos>, run the apply command before exiting the cos:<named-cos> context to implement the changes.
The following commands are available in the cos:<named-cos> context.
Print
this page
Email this topic
Feedback
