Use the process-client-ie command to enable or disable the processing of Information Element 10 (IE 10). The process-client-ie command is accessible from the wlan:<WLAN-service-name>:rf context of the CLI.
After you run the process-client-ie command, run the apply command to implement the changes.
| enable | disable | Enables or disables the processing of Information Element 10 (IE 10) on the Wireless Appliance. |
The following example enables IE 10 processing:
EWC.extremenetworks.com:wlans:CNL-7-CP:rf# process-client-ie enable EWC.extremenetworks.com:wlans:CNL-7-CP:rf# apply
Print
this page
Email this topic
Feedback
