Use the mac-acct command in the wlans:<WLAN-service-name>:auth context to enable or disable the beginning of RADIUS accounting after MAC-based authorization completes.
After you run the mac-acct command, run the apply command to implement the changes.
| enable | Enables the recording of MAC account records on RADIUS after authorization. |
| disable | Disables the recording of MAC account records on RADIUS after authorization. |
This command is available only when MAC-based authorization is enabled (see mac command in the wlan:<WLAN-service-name>:auth context).
This example disables RADIUS recording of MAC records after authentication:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# mac-acct disable EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply
Print
this page
Email this topic
Feedback
