The auth command moves you into the authentication context, wlans:<WLAN-service-name>:auth, for the configuration of authentication settings for the WLAN service being configured. The WLANS auth context supports the following authentication types:
When you first enter the auth context, MAC, 802.1x and Captive Portal Authentication modes default to disabled. MAC authentication can be configured in any authentication mode. The availability of non-MAC authentication commands depends upon the current mode. The Usage section for each authentication command specifies mode information for that command. See mode for further information on setting the authentication mode.
The following commands are available in the wlans:<WLAN-service-name>:auth context.
Print
this page
Email this topic
Feedback
