Use the dot11e command to enable or disable 802.11e radio QoS support. The dot11e command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the dot11e command, run the apply command to implement the changes.
| enable | disable | Specify to enable or disable 802.11e radio QoS support |
The following example enables 802.11e support on the Wireless Appliance:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# dot11e enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show dot11e 802.11e: enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy#
Print
this page
Email this topic
Feedback
