Use the antennaright command to select an antenna supported by the Wireless AP. This command is accessible from the <serial> context of the CLI if the AP supports configuration of a right antenna. To display a list of the available antenna models, enter the command without arguments.
The antenna commands available are dependent on the AP type.
| antenna_model | Model name of an antenna supported by the Wireless AP. |
This example lists the valid antenna models that can be entered with this command, then executes the command with an appropriate model number:
EWC.extremenetworks.com:ap:0500010032150135# antennaright Usage: antennaright <antenna_model> antenna_model: <list of valid antenna models> WS-ANT01 AG 4dBi Omni Factory No Antenna EWC.extremenetworks.com:ap:0500010032150135# antennaright WS-ANT01 AG 4dBi Omni Factory
This example removes a configured right antenna:
EWC.extremenetworks.com:ap:0500010032150135# antennaright No Antenna
Print
this page
Email this topic
Feedback
