Use the channel command to modify the Channel List — scanning on all channels or on the current channels.
After you run the channel command, run the apply command to implement the change.
| all | Specifies all channels to be scanned |
| current | Specifies the current channel to be scanned |
The following example sets the current channel to be scanned:
EWC.extremenetworks.com:mitigator:scgroup:South Block# channel current EWC.extremenetworks.com:mitigator:scgroup:South Block# apply
Print
this page
Email this topic
Feedback
