Use the dtime command to modify the Channel Dwell Time of the scan group.
After you run the dtime command, run the apply command to implement the change.
| 200-5000 | Specifies the dwell time of the scan group in milliseconds. |
The following example sets the channel dwell time of scan group South Block to 200 milliseconds:
EWC.extremenetworks.com:mitigator:scgroup:South Block# dtime 200 EWC.extremenetworks.com:mitigator:scgroup:South Block# apply
Print
this page
Email this topic
Feedback
