Use the interval command to modify the scan time interval in minutes. Valid values are from 10 to 120 minutes.
After you run the interval command, run the apply command to implement the change.
| period | Specifies the scan time interval period in minutes |
The following example modifies the scan time interval to 30 minutes:
EWC.extremenetworks.com:mitigator:scgroup:South Block# interval 30 EWC.extremenetworks.com:mitigator:scgroup:South Block# apply
Print
this page
Email this topic
Feedback
