Use the radio command to modify the radio mode to be used for scanning.
After you run the radio command, run the apply command to implement the change.
| radio1 | Specifies radio 1 to be used |
| radio2 | Specifies radio 2 to be used |
| both | Specifies both radio 1 and radio 2 |
The following example sets radio 1 to be used:
EWC.extremenetworks.com:mitigator:scgroup:South Block# radio1 EWC.extremenetworks.com:mitigator:scgroup:South Block# apply
Print
this page
Email this topic
Feedback
