Use the security-scan command to enable or disable security scanning for rogue APs.
After you run the security-scan command, run the apply command to implement the change.
| enable | Enables security scanning for rogue APs. |
| disable | Disables security scanning for rogue APs. |
The following example enables security scanning:
EWC.extremenetworks.com:mitigator:scgroup:South-Block# security-scan enable EWC.extremenetworks.com:mitigator:scgroup:South Block# apply
Print
this page
Email this topic
Feedback
