Use the sgname command to create a scan group. Use the no form of the command to delete the scan group. The sgname command is accessible from the mitigator:scgroup context of the CLI.
After you add the Wireless APs to the scan group, run the apply command to implement the changes.
| scan group name | Specifies the scan group name |
| 10-120 | Specifies the scan time interval |
| dtime 1-1000 | Specifies the Channel Dwell Time of the scan group |
| radio1 | radio2 | both | Specifies radios — radio 1, radio 2, or both |
| channel all | current | Specifies the channels to be scanned — all or current |
| type active | passive | Specifies the scan type — active or passive |
| serial | Specifies to add the Wireless APs by their serial numbers to the scan group. |
| serial | Specifies the serial number of the Wireless APs that are to be added to the scan group |
The following example creates a scan group named South-Block:
EWC.extremenetworks.com:mitigator:scgroup# sgname South-Block 100 dtime 300 radio both channel all type active serial 0500006072051354 0500006072051427 0500006062051048 0500006062051040
