Use the type command to modify the scan type — active or passive.
After you run the type command, run the apply command to implement the change.
| active | Specifies active type scanning |
| passive | Specifies passive type scanning |
The following example sets the scan type to active:
EWC.extremenetworks.com:mitigator:scgroup:South Block# type active EWC.extremenetworks.com:mitigator:scgroup:South Block# apply
Print
this page
Email this topic
Feedback
