AP Default Settings
| Field | Description |
| AP Properties | |
| LLDP | Determines if the AP broadcasts LLDP (Link Layer Discovery
Protocol) information. This option is disabled by default. If SNMP is enabled on the controller and you enable LLDP, the LLDP Confirmation dialog is displayed. Select one of the following:
| Announcement Interval | Determines how often the AP advertises its
information by sending a new LLDP (Link Layer Discovery Protocol) packet when LLDP is
enabled. This value is measured in seconds. If there are no changes to the AP configuration
that impact the LLDP information, the AP sends a new LLDP packet according to this
schedule. Note: Announcement Interval is not applicable on all AP
models.
| Announcement Delay | Determines the length of time that delays the new
packet delivery. The announcement delay helps minimize LLDP (Link Layer Discovery Protocol)
packet traffic when LLDP is enabled. This value is measured in seconds. If a change to the
AP configuration occurs which impacts the LLDP information, the AP sends an updated LLDP
packet. Note: Announcement Delay is not applicable on all AP
models.
| Time to Live | Determines the lifespan of the LLDP (Link Layer Discovery
Protocol) packet. The Time to Live value is calculated as four times the Announcement
Interval value. It cannot be directly edited. Note: Time to Live is not applicable on all AP
models.
| Country | Select the country of operation. |
| Radio Settings (Radio 1 and Radio 2) | |
| Admin mode | Select On to enable this radio; Select Off to disable this radio. |
| Radio mode | Click the radio mode based on the type of AP. For more information on the available
Radio modes, see Configuring Wireless AP Radio Properties. The available radio settings are dependent on the radio mode you select. |
| Channel Width | Click the channel width for the radio:
| RF Domain | Uniquely defines a group of APs that cooperate in managing RF channels and transmission power levels. The maximum length of the string is 16 characters. |
| Auto Tx Power Ctrl (ATPC) | Determines if the AP will automatically adapt transmission
power signals. Click to either enable or disable ATPC from the Auto Tx Power Ctrl
drop-down list. ATPC automatically adapts transmission power signals according to
the coverage provided by the AP. After a period of time, the system stabilizes
itself based on the RF coverage of your Wireless APs. Note: When enabled, Min Tx
Power and Auto Tx Power Ctrl Adjust parameters can be edited, and the ATPC
algorithm will adjust the AP power between Max Tx power and Min Tx Power. When
disabled, the Max Tx Power selected value or the largest value in the compliance
table will be the power level used by the radio, whichever is
smaller.
| Max Tx Power | Click the appropriate Tx power level from the Max TX Power
drop-down list. The values in the Max TX Power drop-down are in dBm and will vary by
AP. The values are governed by compliance requirements based on the country, radio,
and antenna selected. Changing this value below the current Min Tx Power value will
change the Min Tx Power to a level lower than the selected Max TX Power. Note:
If Auto Tx Power Ctrl (ATPC) is disabled, the selected value or the largest value
in the compliance table will be the power level used by the radio, whichever is
smaller.
| Min Tx Power | If ATPC is enabled, select the minimum Tx power level that is
equal or lower than the maximum Tx power level. We recommend that you use the
lowest supported value if you do not want to limit the potential Tx power level
range that can be used. Note: The Min Tx Power setting cannot be set higher
than the Max Tx Power setting.
| Auto Tx Power Ctrl Adjust | The Auto Tx Power Ctrl Adj parameter is a correction parameter that allows you to manually adjust (up or down) the Tx Power calculated by the ATPC algorithm. If ATPC is enabled, click the Tx power level that can be used to adjust the ATPC power levels that the system has assigned. Extreme Networks recommends that use 0 dB during your initial configuration. If you have an RF plan that recommends Tx power levels for each AP, compare the actual Tx power levels your system has assigned against the recommended values your RF plan has provided. Use the Auto Tx Power Ctrl Adjust value to achieve the recommended values. Valid range is from -(Max Tx Power - Min Tx Power) dB to (Max Tx Power - Min Tx Power) dB. |
| Channel Plan | If ACS is enabled you can define a channel plan for the AP.
Defining a channel plan allows you to limit which channels are available for use
during an ACS scan. For example, you may want to avoid using specific channels
because of low power, regulatory domain, or radar interference. For 5 GHz Radio nodes, click one of the following:
For 2.4 GHz Radio nodes, click one of the following:
| Antenna Selection | Antenna Selection — Click the antenna, or antenna
combination, you want to configure on this radio. When you configure 11n Wireless APs to use specific antennas, the transmission power is recalculated; the Current Tx Power Level value for the radio is automatically adjusted to reflect the recent antenna configuration. It takes approximately 30 seconds for the change to the Current Tx Power Level value to be reflected in the ExtremeWireless Assistant. Also, the radio is reset causing client connections on this radio to be lost. Note: Antenna Selection is not
applicable on all AP models.
| Advanced dialog – AP Properties | |
| Poll Timeout | Type the timeout value, in seconds. The AP uses this value to
trigger re-establishing the link with the controller if the AP does not get an
answer to its polling. The default value is 10 seconds. Note: If you are
configuring session availability, the Poll Timeout value should be 1.5 to 2 times
of Detect link failure value on AP Properties screen. For
more information, see Session Availability.
| Secure Tunnel | This feature, when enabled, provides encryption,
authentication, and key management between the AP and/or controllers. Select the desired Secure Tunnel mode from the drop-down list:
Note: Changing a Secure Tunnel mode will automatically disconnect
and reconnect the AP.
| Secure Tunnel Lifetime | Enter an interval (in hours) at which time the keys of the
IPSEC tunnel are renegotiated. Note: Changing the Secure Tunnel Lifetime setting will
not cause any AP disruption.
| Remote Access | Click to Enable or Disable SSH to the AP. |
| Location-based Service | Click to Enable or Disable location-based service on this AP. Location-based service allows you to use this AP with an AeroScout or Ekahau solution. |
| Maintain client sessions in event of poll failure | Click to Enable or Disable (using a bridged at AP VNS) the AP remains active if a link loss with the controller occurs. This option is disabled by default. |
| Restart service in the absence of controller | Click to Enable or Disable (if using a bridged at AP VNS) to ensure the AP continues providing service if the AP‘s connection to the controller is lost. If this option is enabled, it allows the AP to start a bridged at AP VNS even in the absence of a controller. |
| Use broadcast for disassociation | Click to Enable or Disable if you want the AP to use
broadcast disassociation when disconnecting all clients, instead of disassociating
each client one by one. This affects the behavior of the AP under the following
conditions:
| IP Multicast Assembly | Click to Enable or Disable multicast frames assembling for groups of APs using AP Multi-editing settings (for more information, see AP Multi-Edit Properties ). |
| Balanced Channel List Power: | This simplifies power settings such that they will function across all channels in the channel plan. |
| LED | Select the desired LED pattern from the drop-down list. Options include: Off, WDS Signal Strength, Identify, and Normal. |
| Radio Settings | |
| DTIM | Type the desired DTIM (Delivery Traffic Indication Message) period — the number of beacon intervals between two DTIM beacons. To ensure the best client power savings, use a large number. Use a small number to minimize broadcast and multicast delay. The default value is 5. |
| Beacon Period | Defines the time, in milliseconds, between beacon transmissions. The default value is 100 milliseconds. |
| RST/CTS | Type the packet size threshold, in bytes, above which the packet will be preceded by an RTS/CTS (Request to Send/Clear to Send) handshake. The default value is 2346, which means all packets are sent without RTS/CTS. Reduce this value only if necessary. |
| Frag. Threshold | Type the fragment size threshold, in bytes, above which the packets will be fragmented by the AP prior to transmission. The default value is 2346, which means all packets are sent un-fragmented. |
| Dynamic Channel Selection | Click one of the following:
| DCS Noise Threshold | Type the noise interference level, measured in dBm, after which ACS scans for a new operating channel for the AP if the threshold is exceeded. |
| DCS Channel Occupancy Threshold | Type the channel utilization level, measured as a percentage, after which ACS scans for a new operating channel for the AP if the threshold is exceeded. |
| DCS Update Period | Type the time, measured in minutes that determines the period during which the AP averages the DCS Noise Threshold and DCS Channel Occupancy Threshold measurements. If either one of these thresholds is exceeded, then the AP triggers ACS. |
| DCS Interference Event (appears if Dynamic Channel Selection is enabled) |
Enable or disable the following DCS Events:
| Interference Wait Time | Length of the delay (in seconds) before logging an alarm. Default setting is 10 seconds. |
| Preamble | Click a preamble type for 11b-specific (CCK) rates: Short, or Long. Click Short if you are sure that there is no 11b APs or client in the vicinity of this AP. Click Long if compatibility with 11b clients is required. |
| Protection Rate | Click a protection rate: 1, 2, 5.5, or 11 Mbps. The default and recommended setting is 11. Only reduce the rate if there are many 11b clients in the environment or if the deployment has areas with poor coverage. For example, rates lower than 11 Mbps are required to ensure coverage. |
| Protection Mode | Click a protection mode: None, Auto, or Always. The default and recommended setting is Auto. Click None if 11b APs and clients are not expected. Click Always if you expect many 11b-only clients. |
| Protection Type | Click a protection type, CTS Only or RTS CTS, when a 40 MHz or 80 MHz channel is used. This protects high throughput transmissions on extension channels from interference from non-11n APs and clients. |
| Max % of non-unicast traffic per Beacon period | Enter the maximum percentage of time that the AP transmits non-unicast packets (broadcast and multicast traffic) for each configured Beacon Period. For each non-unicast packet transmitted, the system calculates the airtime used by each packet and drops all packets that exceed the configured maximum percentage. By restricting non-unicast traffic, you limit the impact of broadcasts and multicasts on overall system performance. |
| Optimized Multicast for power save | Click to optimize for power save. |
| Adaptable rate for Multicast | Click to enable adaptable rate capabilities. |
| Multicast to Unicast delivery | Click to set the Multicast to Unicast delivery method from the drop-down list. |
| Enhanced Rate Control | |
| Min. Basic Rate | For each radio, click the minimum data rate that must be
supported by all stations in a BSS:
| 11n Settings | |
| Protection Type | Click a protection type, CTS Only or RTS CTS, when a 40 MHz channel is used. This protects high throughput transmissions on extension channels from interference from non-11n APs and clients. |
| Extension Channel Busy Threshold | Type the extension channel threshold percentage, which if exceeded, disables transmissions on the extension channel (40 MHz). |
| Aggregate MSDUs | Click an aggregate MSDU mode: Enabled or Disabled. Aggregate MSDU increases the maximum frame transmission size. |
| Aggregate MPDUs | Click an aggregate MPDU mode: Enabled or Disabled. Aggregate MPDU provides a significant improvement in throughput. |
| Aggregate MPDU Max Length | Type the maximum length of the aggregate MPDU. The value range is 1024-65535 bytes. |
| Agg. MPDU Max # of Sub-frames | Type the maximum number of sub-frames of the aggregate MPDU. The value range is 2-64. |
| ADDBA Support | Click an ADDBA support mode: Enabled or Disabled. ADDBA, or block acknowledgement, provides acknowledgement of a group of frames instead of a single frame. ADDBA Support must be enabled if Aggregate MPDU is enable. |
| LDPC | Click an LDPC mode: Enabled or Disabled. LDPC increases the reliability of the transmission resulting in a 2dB increased performance compared to traditional 11n coding. |
| STBC | Click an STBC mode: Enabled or Disabled. STBC is a simple open loop transmit diversity scheme. When enabled, STBC configuration is 2x1 (two spatial streams combine into one spatial stream). TXBF will override STBC if both are enabled for single stream rates. |
| TxBF |
Tx Beam Forming is a technique of re-aligning the transmitter multipath spatial streams phases in order to get better signal-to-noise ratio on the receiver side. Click a TXBF mode: For the AP37xx and AP38xx models, valid values are Enabled or Disabled. For the 39xx APs, this setting is only available on Radio1 and valid values are MU-MIMO and Disabled. |
