Message Configuration Page - Fields and Buttons
| Field/Button | Description |
| Invalid | Enter a message indicating that the user entered an invalid username or password combination. |
| Success | Enter a message to indicate when a user successfully logs in. |
| Access Fail | Enter an error message that indicates the a user login was unsuccessful. |
| Fail | Enter a message indicating an internal error. |
| Timeout | Enter an error message indicating that the user authentication timed out. |
| RADIUS shared secret security key fail | Enter an error message indicating that RADIUS shared secret failed. |
| RADIUS internal error | Enter an error message indicating an internal RADIUS client error |
| Max RADIUS login fail | Enter a message that indicates that the maximum number of simultaneous captive portal logins have been reached. |
| Invalid Login parameters | Enter a message indicating that the user entered an invalid username or password combination. |
| General failure | Enter a message indicating that a general failure has occurred. |
| Invalid third party parameters | Enter an error message indicating that one or more parameters passed from the external captive portal server to the controller is either invalid or missing. |
| Authentication in progress fail | Enter a message indicating that the user credentials were not authenticated. |
| Topology Change | Enter an error message indicating that the topology failed. |
| Close | Click to save your changes and close this page. |
| Cancel | Click to discard your configuration changes and close this page. |
