Radio Actions
| Field | Description |
| Set Tx Power |
Apply this command to selected APs. All selected APs must be the same model and licensed for the same country. Configure the setting from the resulting dialog. First, configure the selected APs to the same radio mode and same channel width before setting Tx Power here. When selected AP‘s are configured for the same width/mode, the Set Tx Power dialog displays the width/mode and you are able to set the Tx power and channel. For more information, see Configuration Parameters for Radio Properties. |
| Auto Channel Select | Apply this command to selected APs. For more information about ACS, see Dynamic Radio Management (DRM). |
| Set Radio Mode |
Apply this command to selected APs. All selected APs must be the same model and licensed for the same country. Configure the setting from the resulting dialog. For more information, see Configuration Parameters for Radio Properties. |
| Set Channel Width |
