Configuring Common Configuration Default AP Settings
To configure common configuration default AP settings:
  1. From the top menu, click AP.
  2. In the left pane, click Global > Default Settings.
    The Common Configuration tab is displayed.
    Graphics/ap_default_common_config.png
  3. In the Static Configuration section, you can specify an EWC search list or use the search list provided from the AP. Do one of the following:
    Check Learn EWC Search List from AP to accept the AP's search list, or clear the checkbox to specify a common search list for all APs. For more information about creating an EWC Search List, see Static Configuration Properties.
  4. In the WLAN Assignments section, you can associate a WLAN assignment to a radio.
    • If the controller is in an availability pair, you can apply default WLAN assignments to foreign APs, by selecting the Apply default WLAN assignments to foreign APs checkbox. For more information, see Availability.
    • To assign Associate radios for each WLAN Service in the list, select the box next to each radio. You can assign specific client ports to each WLAN Service associated with the AP3912.
      • A WLAN service can have one or more port assignments, but a client port can be assigned to only one WLAN service.
      • If the port does not have a WLAN service assignment, the port is disabled.
      • One policy definition for wired and wireless users. Users on wired ports receive the same default policy.
      • Wired ports can only be assigned to open WLAN services. There is no security or privacy on the client ports.
  5. Click Save Settings.
