Configuring a Basic Topology
To configure a
basic topology:
From the top menu, click
VNS. Then, in
the left pane, select Topologies. The
Topologies window displays.
Select the topology to
edit or click New to
create a new topology.
Configuring a basic topology
On the General tab, enter a name for
the topology in the Name field.
Select a mode of
operation from the Mode drop-down list. Choices
are:
- Physical — VLAN
identifier (1 - 4094), with at least one layer 2 member port (no mu
associated).
- Routed — Routed
topologies do not require Layer 2 configuration (controller internal VLAN
identifier from valid range 1- 4094), and Layer 3 configuration. See Layer 3 Configuration for more
information.
- Bridge Traffic Locally at
AP — Requires Layer 2 configuration. Does not require Layer
3 configuration. Bridge Traffic at the AP VNSs do not require the definition
of a corresponding IP address since all traffic for users in that VNS will
be directly bridged by the Wireless AP at the local network point of
attachment (VLAN at AP port).
EWC
— Requires Layer 2 configuration. May optionally have Layer 3 configuration.
Layer 3 configuration would be necessary if services (such as DHCP, captive
portal, etc.) are required over the configured network segment, or if
controller management operations are intended to be done through the
configured interface.
Configure the Layer 2
VLAN Settings, depending on
the previously selected Mode.
- For Physical, enter a VLAN
identifier (2 - 4094), with at least one layer 2 member port (no mu
associated).
- For Bridge Traffic Locally at
EWC, enter a VLAN
identifier (2- 4094) that is valid for your system and enter the port to
which this VLAN is attached to, according to the networking deployment model
pre-established during planning.
AP, enter a VLAN identifier (1 - 4094), 4094 is reserved for
Internal VLAN ID.
- Specify whether the VLAN configuration is
Tagged
or
Untagged.
- To eliminate ARP Request Broadcast on the
Wireless network, select ARP
Proxy. ARP Proxy applies to traffic for Bridge Traffic Locally at
AP Toplogies. ARP Proxy is configurable per
topology.
- For Port, select the Physical
(Ethernet) or Link Aggregation (LAG) data port. For more information, see
Viewing and Changing the L2 Ports Information.
Click Save to save your
changes.
These steps are
sufficient to create and save a topology. The following configuration options are
optional and depend on the mode of the topology.
