Configuring ToS/DSCP Marking
To configure ToS/DSCP
marking:
From the Class of
Service General tab, click ToS/DSCP
Marking.
Click the Select button.
The
ToS/DSCP Configuration dialog displays:
Select either
Type of Service (ToS) or
Diffserv Codepoint (DSCP) from
this dialog. You cannot configure both types.
If you select Type of Service (ToS):
Select a Precedence value from the drop-down
list.
Select a specific ToS from the following
list:
- Delay Sensitive
- High Throughput
- High Reliability
- Explicit Congestion Notification
If you select
Diffserv Codepoint (DSCP):
- Choose a Well-known Value, or
- Enter a Raw Binary Value
Close the
Configuration dialog.
The logic used to find the final User Priority (UP) depends on the CoS, the received UP, or the final ToS/DSCP value. Here are the steps followed to determine the final UP:
Use UP markings defined in CoS (directly or via Legacy UP override).
If still no UP, use UP from the received packet.
If still no UP, use DSCP marking defined in CoS and map to UP with WLANs DSCP-to-UP mapping table.
If still no UP, use received DSCP value and map to UP with WLANs DSCP-to-UP mapping table.
