Use this task to configure static routes for Management Instances.
Up to 100 IPv4 and IPv6 static routes can be configured.
Add a static route to configure routing for a Management Instance:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt vlan Switch:1(mgmt:vlan)#ip route 192.0.2.2/24 next-hop 198.51.100.1
Variable definitions
The following table defines parameters for the ip route and ipv6 route commands.
Variable |
Value |
<A.B.C.D A.B.C.D | A.B.C.D/X> |
Specifies the IP address and mask in one of the following formats:
next-hop <A.B.C.D> or next-hop WORD<0-255> |
Specifies the next hop address for the static route. Use an IP in the same subnet as the management VLAN IP address. |
weight <1–65535> |
Specifies the static route cost. The default is 100 for CLIP, 200 for VLAN, and 300 for OOB. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100. |
WORD<0-255> |
Specifies the IPv6 address. |
