Perform this procedure to specify the RSTP mode.
Configure Rapid Spanning Tree Protocol version:
Switch:1(config)# spanning-tree rstp version rstp
Variable definitions
Use the data in the following table to use the spanning-tree rstp version command.
Variable |
Value |
rstp version {rstp|stp-compatible} |
Sets the version to RSTP or to STP compatible. The default is RSTP. |
