View RMON control tables to see the data source for both network layer and application layer host statistics.
Switch:1# show rmon ctl-table
Rmon Control Table
Protocol Directory Table
IDX PROTOCOL ADDRMAPCFG HOSTCFG MATRIXCFG OWNER
1 IP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
2 TCP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
3 UDP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
4 FTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
5 SSH SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
6 TELNET SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
7 HTTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
8 RLOGIN SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
9 TFTP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
10 SNMP SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
11 HTTPS SUPPORTED SUPPORTED NOT SUPPORTED Switch-1
Protocol Distribution Control Table
IDX DATASOURCE DROPFRAMES CREATETIME OWNER
1 0.0.0.0 0 09/22/15 19:29:13 Switch-1
Address Map Control Table
IDX DATASOURCE DROPFRAMES OWNER
1 0.0.0.0 0 Switch-1
Host Control Table
IDX DATASOURCE NHDROPFRAMES AHDROPFRAMES OWNER
1 0.0.0.0 0 0 Switch-1
Protocol support can vary across platforms.
Job Aid
The following table describes the fields in the output for the show rmon ctl-tabl command.
Parameter |
Description |
ADDRMAPCFG |
Describes and configures the probe support for the network layer
and application layer host tables for this protocol. The value can
be one of the following:
If the value is SUPPORTED ON, the probe adds entries to the address map table that maps the network layer address to the MAC layer address. |
AHDROPFRAMES |
Shows the total number of application layer host frames that the probe receives and drops. This value does not include packets that were not counted because they had MAC-layer errors. |
CREATETIME |
Shows when the entry was last activated. |
DATASOURCE |
Shows the source of data for the entry. |
DROPFRAMES |
Shows the total number of frames that the probe receives and drops. This value does not include packets that were not counted because they had MAC-layer errors. |
HOSTCFG |
Describes and configures the probe support for the network layer and application layer host tables for this protocol. The value can be one of the following:
If the value is SUPPORTED ON, the probe adds entries to the Host Control table to collect statistics for network layer and application layer hosts. |
IDX |
Shows a unique identifier for the entry in the table. |
MATRIXCFG |
NHDROPFRAMES |
Shows the total number of network host frames that the probe receives and drops. This value does not include packets that were not counted because they had MAC-layer errors. |
OWNER |
Shows the entity that configured this entry. |
PROTOCOL Protocol support can vary across hardware models. |
Shows the protocols RMON2 can monitor:
