Display individual RMON statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View RMON statistics:
Switch:1>enable
Switch:1#show interfaces gigabitEthernet statistics rmon 1/13
Port Stats Rmon
PORT OCTETS PKTS MULTI BROAD CRC UNDER OVER FRAG COLLI
NUM CAST CAST ALLIGN SIZE SIZE MENT SION
1/13 1943 21 8 13 0 0 0 0 0
Use the data in the following table to use the show interfaces GigabitEthernet statistics rmon command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Job Aid
The following table describes parameters for the show interfaces GigabitEthernet statistics rmon command output.
Parameter |
Description |
PORT NUM |
Indicates the port number. |
OCTETS |
The total number of octets of data (including those in bad packets) received on the network (excluding framing bits but including FCS octets). |
PKTS |
The total number of packets (including bad packets, broadcast packets, and multicast packets) received. |
MULTICAST |
The total number of packets received that were directed to a multicast address. This number does not include packets directed to the broadcast address. |
BROADCAST |
The total number of packets received that were directed to the broadcast address. This number does not include multicast packets. |
CRC ALLIGN |
The total number of packets received that had a length (excluding framing bits, but including FCS octets) between 64 and 1518 octets, inclusive, but had either a bad Frame Check Sequence (FCS) with an integral number of octets (FCS Error), or a bad FCS with a nonintegral number of octets (Alignment Error). |
UNDERSIZE |
The total number of packets received that were less than 64 octets long (excluding framing bits, but including FCS octets) and were otherwise well formed. |
OVERSIZE |
The total number of packets received that were longer than 1518 octets (excluding framing bits, but including FCS octets) and were otherwise well formed. |
FRAGMENT |
The total number of packets received that were less than 64 octets in length (excluding framing bits but including FCS octets) and had either a bad Frame Check Sequence (FCS) with an integral number of octets (FCS Error) or a bad FCS with a nonintegral number of octets (Alignment Error). |
COLLISION |
An estimated value for the total number of collisions on this Ethernet segment. |
