View PIM-SM neighbor parameters to troubleshoot connection problems or review the configuration.
- In the navigation pane, expand the following folders: .
- Click PIM.
- Click the Neighbors tab.
Neighbors field descriptions
Use the descriptions in the following table to use the Neighbors tab.
Name |
Description |
Address |
Shows the IP address of the PIM neighbor. |
IfIndex |
Shows the slot and port number or VLAN ID of the interface used to reach this PIM neighbor. |
UpTime |
Shows the time since this neighbor became a neighbor of the local router. |
ExpiryTime |
Shows the time remaining before the neighbor expires. |
