Use this procedure to determine the protocol configured on the added VLAN.
The protocol configured on the added VLAN can be one of the following values:
snoop
snoop-spb
route-spb
pim
Determine the protocol configured on the added VLAN:
Switch:1#show ip igmp interface
Igmp Interface - GlobalRouter
QUERY OPER QUERY WRONG LASTMEM
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE L2ISID
V100 125 activ 2 2 0.0.0.0 100 0 0 2 10 snoop-spb 1100
1 out of 1 entries displayed
The following table defines parameters for the show ip igmp interface command.
Variable |
Value |
gigabitethernet{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vlan<1-4059> |
vrfWORD<1–16> |
Specifies the VRF instance by the VRF name. |
vrfidsWORD<0–512> |
Specifies the VRF ID for which to display statistics. |
Job Aid
The following table shows the field descriptions for the show ip igmp interface command.
Field |
Description |
IF |
Indicates the interfaces where IGMP is configured. |
QUERY INTVL |
Indicates the frequency at which the interface transmits IGMP host query packets. |
STATUS |
Indicates the activation of a row that enables IGMP on the interface. The destruction of a row disables IGMP on the interface. |
VERS |
Indicates the version of IGMP that runs on this interface. This object configures a router capable of running either version. For IGMP to function correctly, you must configure all routers on a LAN to run the same version of IGMP. |
OPER VERS |
Indicates the operational version of IGMP. |
QUERIER |
Indicates the address of the IGMP querier on the IP subnet to which this interface is attached. |
QUERY MAXRSPT |
Indicates the maximum query response time (in tenths of a second) advertised in IGMPv2 queries on this interface. |
WRONG QUERY |
Indicates the number of queries received whose IGMP version does not match the IGMP Interface version. You must configure all routers on a LAN to run the same version of IGMP. Therefore, if the interface receives queries with the wrong version, a configuration error occurs. |
JOINS |
Indicates the number of times IGMP added a group membership on this interface. |
ROBUST |
Indicates the robustness variable, which you configure for the expected packet loss on a subnet. If packet loss is expected on a subnet, increase the robustness variable. |
LAST MEM QUERY |
Indicates the maximum response time (in tenths of a second) inserted into group-specific queries sent in response to leave group messages, and is also the amount of time between group-specific query messages. Use this value to modify the leave latency of the network. A reduced value results in reduced time to detect the loss of the last member of a group. This does not apply if igmpInterface version is 1. |
MODE |
Indicates the protocol configured on the VLAN added.
The following table shows the field descriptions for the show ip igmp interface command output if you use the optional parameters to specify a port, VLAN, or VRF.
Field |
Description |
VLAN ID or PORT NUM |
Identifies the VLAN or port where IGMP is configured. |
QUERY INTVL |
Indicates the frequency at which IGMP host query packets transmit on this interface. |
QUERY MAX RESP |
ROBUST |
Indicates the robustness variable, which you can configure for the expected packet loss on a subnet. If you expect packet loss on a subnet, increase the robustness variable. |
VERSION |
LAST MEMB QUERY |
Indicates the maximum response time (in tenths of a second) inserted into group-specific queries sent in response to leave group messages, and is also the amount of time between group-specific query messages. Use this value to modify the leave latency of the network. A reduced value results in reduced time to detect the loss of the last member of a group. This variable does not apply to IGMPv1. |
PROXY SNOOP ENABLE |
Indicates if proxy snoop is enabled on the interface. |
SNOOP ENABLE |
Indicates if snoop is enabled on the interface. |
SSM SNOOP ENABLE |
Indicates if SSM snoop is enabled on the interface. |
FAST LEAVE ENABLE |
Indicates if fast leave mode is enabled on the interface. |
FAST LEAVE PORTS (VLAN parameter only) |
Indicates the set of ports that are enabled for fast leave. |
SNOOP QUERIER ENABLE (VLAN parameter only) |
Indicates if the IGMP Layer 2 Querier feature is enabled. |
SNOOP QUERIER ADDRESS (VLAN parameter only) |
Indicates the IP address of the IGMP Layer 2 Querier. |
DYNAMIC DOWNGRADE VERSION |
Indicates if the dynamic downgrade feature is enabled. |
COMPATIBILITY MODE |
Indicates if compatibility mode is enabled. |
EXPLICIT HOST TRACKING |
Indicates if explicit host tracking is enabled to track all the source and group members. |
