Enable ARP on the device so that it answers local ARP requests.
You can enable or disable ARP responses on the device. You can also enable ARP proxy, which lets a router answer a local ARP request for a remote destination.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]} or interface vlan <1–4059>
ip arp-response
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 200 Switch:1(config-if)#ip arp-response
