Use this procedure to view the LLDP local system information.
- Click LLDP.
- Click the Local System tab.
Local System field descriptions
Use the data in the following table to use the Local System tab.
Name |
Description |
ChassisIdSubType |
Indicates the encoding used to identify the local system chassis.
ChassisId |
Indicates the chassis ID of the local system. |
SysName |
Indicates local system name. |
SysDesc |
Indicates local system description. |
SysCapSupported |
Indicates the system capabilities supported on the local system. |
SysCapEnabled |
Indicates the system capabilities that are enabled on the local system. |
