Use this procedure to configure the device subject parameters to identify the device, such as the name, Email ID, company, department, and location.
Configuring subject parameters:
Switch:1>enable Switch:1#configure terminal Switch:1(config)# certificate subject common-name Self e-mail example@company.com unit Engineering organization Company locality SanFrancisco province California country US
The following table defines parameters for the Certificate Subject command.
                                 Variable  |
                                 Value  |
                                 common-name WORD<0–64>  |
                                 Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 country WORD<2-2>  |
                                 Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 e-mail WORD<0-254>  |
                                 Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 locality WORD<0-128>  |
                                 Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 organization WORD<0-64>  |
                                 Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 province WORD<0-128>  |
                                 Specifies the province of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 unit WORD<0-64>  |
                                 Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority.  |
