Viewing IPv6 OSPF Statistics
View OSPF statistics to analyze trends.
View IPv6 OSPF statistics:
Switch:1>enable
Switch:1#show ipv6 ospf statistics
OSPFv3 Statistics - GlobalRouter
NumTxPkt: 9958
NumRxPkt: 8982
NumTxDropPkt: 33
NumRxDropPkt: 0
NumRxBadPkt: 0
NumSpfRun: 42
LastSpfRun: 0 day(s), 02:44:32
LsdbTblSize: 45
NumBadLsReq: 0
NumSeqMismatch: 0
NumOspfAdjacencies: 7
Job Aid
The following table explains the output of the show ipv6 ospf statistics command.
Field |
Description |
NumTxPkt |
Shows the count of sent packets. |
NumRxPkt |
Shows the count of received packets. |
NumTxDropPkt |
Shows the count of sent, dropped packets. |
NumRxDropPkt |
Shows the count of received, dropped packets. |
NumRxBadPkt |
Shows the count of received, bad packets. |
NumSpfRun |
Shows the count of intra-area route table updates with calculations using this area link-state database. |
LastSpfRun |
Shows the count of the most recent SPF run. |
LsdbTblSize |
Shows the size of the link-state database table. |
NumBadLsReq |
Shows the count of bad link requests. |
NumSeqMismatch |
Shows the count of sequence mismatched packets. |
Use the data in the following table to use the show ipv6 ospf stats command.
Variable |
Value |
vrf WORD<1-16> |
Specifies the VRF name. |
vrfids WORD<0-512> |
Specifies VRF IDs. |
