Configure a UDP port forward entry to add or remove a port forward entry.
Configure a UDP port forward entry:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip forward-protocol udp portfwd 150 192.0.2.10
Variable definitions
Use the data in the following table to use the ip forward-protocol udp portfwd command.
Variable |
Value |
<1-65535> {A.B.C.D} |
Adds a UDP protocol port to the specified port forwarding list. 1-65535 is a UDP protocol port in the range of 1–65535. A.B.C.D is an IP address in a.b.c.d format. Use the no operator to remove a protocol port forwarding entry and IP address from the list: no ip forward-protocol udp portfwd <1-65535> <A.B.C.D>. To configure this option to the default value, use the default operator with this command. |
vrf WORD<0-16> |
Specifies the name of the VRF. |
vrfids WORD<0-512> |
Specifies the ID of the VRF. |
