Configure the sFlow agent IPv4 address, and then enable sFlow before the system can monitor and capture traffic statistics to send to an sFlow collector. By default, sFlow is globally disabled.
Globally enable sFlow, and then verify the configuration.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#sflow agent-ip 192.0.2.27
INFO: Please be aware that sFlow agent IP address is only supported in MGMT or GRT VRF.
Switch:1(config)#sflow enable
Switch:1(config)#show sflow
sFlow Global Configuration
Global State : Enabled
Agent IP : 192.0.2.27
What to do next
After you configure the agent-ip and globally enable sFlow, proceed to configuring the sFlow collector.
Use the data in the following table to use the sflow agent-ip command.
Variable |
Definition |
{A.B.C.D.} |
Specifies the agent-ip address (IPv4). Note:
For Segmented Management Instance interfaces, you must configure the agent-ip address to the IP address of the Segmented Management Instance interface on which datagrams egress. |
