Use the show ipv6 mroute next-hop command to display the IPv6 mroute next-hop information. The syntax for this command is as follows.
show ipv6 mroute next-hop vlan <1-4059>
Switch:1(config)#show ipv6 mroute next-hop vlan 2
Mroute Next-Hop - GlobalRouter
Vlan: VLAN 2
Port: -
Group: ff30:0:0:0:0:0:0:1
Source: 5010:0:0:0:0:1:82:10
Source Mask: 64
State: pruned
Expire Time: 202
Protocol: pimsm
Closest Member Hops: 0
Vlan: VLAN 2
Port: -
Source: 5010:0:0:0:0:1:82:11
Source Mask: 64
State: pruned
Expire Time: 175
Protocol: pimsm
2 out of 4 total mroute entries displayed
The following table shows the field descriptions for this command.
Field |
Description |
Group |
Displays the IPv6 multicast group for this entry that specifies a next hop on an outgoing interface. |
Source |
Displays the network address that, when combined with the corresponding next hop SourceMask value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
Source Mask |
Displays the network mask that, when combined with the corresponding next hop Source value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
State |
Displays whether the outgoing interface and next hop represented
by this entry is currently being used to forward IPv6 datagrams as
one of the following:
Expire Time |
Displays the minimum amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging. |
Protocol |
Displays the protocol as one of the following:
Closest Member Hops |
Displays the minimum number of hops between this router and any member of this IPv6 multicast group reached via this next hop on this outgoing interface. Any IPv6 multicast datagrams for the group which have a TTL less than this number of hops is not forwarded to this next hop. |
