Use the following procedure to display the MSDP global and peer status.
Switch:#enable
Switch:1#show ip msdp summary
MSDP Summary - GlobalRouter
MSDP Status Summary
MSDP Global Status: enabled
cache status: enabled
cache-lifetime: 390 seconds
cache-count: 8
Originator id: 5.5.5.5
Redistribute: route-policy:
SA Limit: 6144
MSDP Peer Status Summary
Peer Address AS State Uptime/ Established SA
Downtime Count Count
4.5.35.3 1 Established 00:00:27 3 8
5.7.56.7 2 Established 00:00:31 2 0
Variable definitions
The following table defines parameters for the show ip msdp summary command.
Variable |
Value |
vrf WORD<0–16> |
Displays configuration information for a particular VRF. |
vrfids WORD<0–512> |
Displays configuration information for a particular VRF ID. |
