The command mode is key for this command. If you are logged on to a different command mode, such as Global Configuration mode, rather than Privileged EXEC mode, different options appear for this command.
Restart the switch to implement configuration changes or recover from a system failure. When you restart the system, you can specify the boot config file name. If you do not specify a boot source and file, the boot command uses the configuration files on the primary boot device defined by the boot config choice command.
After the switch restarts normally, it sends a cold trap within 45 seconds after the restart.
Switch:1> enable
Restart the switch:
Switch:1# boot config /intflash/config.cfg
Switch:1# Do you want to continue? (y/n)
Switch:1# Do you want to continue? (y/n) y
The following table defines parameters for the boot command.
Variable |
Value |
config WORD<1–99> |
Specifies the software configuration device and file name in one of the following formats:
The file name, including the directory structure, can include up to 99 characters. |
-y |
Suppresses the confirmation message before the switch restarts. If you omit this parameter, you must confirm the action before the system restarts. |
