View the DvR interfaces on either a Controller or a Leaf node.
On Controllers, DvR interfaces are created when you configure IP on a DvR enabled Layer 2 VSN (VLAN, I-SID). Only Controllers display the administrative state of the interfaces because this is where you enable or disable the interfaces. On a Leaf node, the DvR interface information that the Controllers push, for example, subnet routes and the gateway IP addresses for the Layer 2 VSNs, are displayed.
Ensure that you enable DvR globally on the node.
Interfaces field descriptions
Use the data in the following table to use the Interfaces tab.
Name |
Description |
VlanIpAddrType |
Specifies the VLAN IP address type of the DvR interface. |
VlanIpAddr |
Specifies the VLAN IP address (IPv4) of the DvR interface. |
L3Isid |
Specifies the Layer 3 I-SID of the DvR interface. The range is 1 to 16777215. |
L2Isid |
Specifies the Layer 2 I-SID of the DvR interface. The range is 1 to 16777215. |
VlanIpMask |
Specifies the VLAN IP address mask of the DvR interface. |
VrfId |
Specifies the VRF ID of the DvR interface. The VRF ID is 0 for the GRT. |
VlanId |
Specifies the VLAN ID of the DvR interface. |
GwIpAddrType |
Specifies the address type of the DvR gateway IP address (IPv4). |
GwIpAddr |
Specifies the DvR gateway IP address (IPv4). |
AdminState |
Specifies the administrative state of the DvR interface. |
SpbmcState |
Specifies the state of IP Multicast over Fabric Connect, on the DvR interface. |
IgmpVersion |
Specifies the version of IGMP that runs on the DvR interface. |
