View RIP status.
- Click RIP.
- Click the Status tab.
Status field description
Use the following table to use the RIP Status tab.
Name |
Description |
Address |
Specifies the IP address of the router interface. |
RcvBadPackets |
Specifies the number of RIP response packets received by the RIP process which were subsequently discarded; for example, version 0 packet, or an unknown command type. |
RcvBadRoutes |
Specifies the number of routes, in valid RIP packets, that are ignored; for example, unknown address family, or invalid metric. |
SentUpdates |
Specifies the number of triggered RIP updates sent on this interface, that do not include full updates sent containing new information. |
