Perform this procedure to create an IPv6 CLIP interface and associate it with a specific VRF.
  1. Enter Loopback Interface Configuration mode
    enable
    configure terminal
    interface Loopback <1-256>
  2. Create an IPv6 loopback interface address:
    ipv6 interface address WORD <0-255> vrf WORD <1–16>
  3. Optional: Enter a name for the IPv6 address:
    ipv6 interface name WORD <0-64>
  4. Ensure the configuration is correct:
    show ipv6 interface loopback <1–256>
Switch:1#show ipv6 interface loopback
                                                Loopback Ipv6 Interfaces
IF   VRF              Descr         VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  IPSEC
INDX NAME                                ADDRESS           STATE   STATE            LMT TIME        TIME        STATE
1348 GlobalRouter     CLIPv6-5      --   00:00:00:00:00:05 enable  up    ETHER 1500 64  30000       1000        disable
                                        Loopback IPv6 Addresses
IPV6 ADDRESS/PREFIX LENGTH                   LOOPBACK-ID  TYPE    ORIGIN    STATUS                    NAME
2001:db8:0:0:0:0:0:ffff/32                   C-5          UNICAST MANUAL    PREFERRED INF      INF    EXTREMESERVER_2
Legend: NA - Information not available
1 out of 1 Total Num of Interface Entries displayed.
1 out of 1 Total Num of Address Entries displayed.
Variable definitions
Use the data in the following table to use the ipv6 commands.
Variable
Value
WORD<1–256>
Specifies the CLIP interface ID.
WORD<0–255>
Specifies the IPv6 address.
vrf WORD<1–16>
Specifies the VRF name.
WORD<0–64>
Specifies the I-SID name associated with the IPv6 address.
