This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to configure the onboarding I-SID for ports that are operating in Auto-sense mode.
Configuring the Auto-sense onboarding I-SID:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense onboarding i-sid 15000000
The following table defines parameters for the auto-sense onboarding command.
Variable |
Value |
i-sid<1-16777215> |
Specifies the service instance identifier (I-SID). The default onboarding I-SID value is 15999999. |
