Use this procedure to configure the VRF timeout value. The timeout value ages out the sender when there is no multicast stream on the VRF. The default is 210 seconds.
You can use this procedure for Layer 3 VSN with IP Multicast over Fabric Connect services and IP Multicast over Fabric Connect for IP Shortcuts.
You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
You must create the C-VLANs and add slots/ports.
You must enable IP Multicast over Fabric Connect globally.
enable
configure terminal
router vrf WORD<1-16>
mvpn fwd-cache-timeout(seconds) <10–86400>
no mvpn fwd-cache-timeout
default mvpn fwd-cache-timeout(seconds)
Configure the timeout value on the VRF to 500 seconds:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf green Switch:1(router-vrf)#mvpn fwd-cache-timeout(seconds) 500
